1. 简介
A kinematics module answers two questions: where the controlled point is for a given set of joint positions, and which joint positions put it at a requested place. kinematicsForward() and kinematicsInverse() are those two answers.
Everything else about a machine’s geometry is currently rebuilt outside the module. A tilted work plane needs the direction the tool points in, a simulation model needs the whole chain of frames, a limit check needs the rate joints move per unit of commanded motion. For the xyzacb-trsrn machine that geometry is written three times: as closed-form expressions in src/hal/components/xyzacb_trsrn.comp, as homogeneous matrices in the config’s remap_funcs_twp.py, and as a chain of HalRotate calls with hand-chosen signs in vismach/xyzacb-trsrn-gui.py. The three copies share no vocabulary and no sign convention, so "the same as" can be checked only by a person reading all three.
This chapter fixes the vocabulary and states the rules, so that two modules written from the same drawing give the same answers and a consumer can say what it needs without naming a machine. Writing a Module collects the rules in one place.
2. Frames
Four frames, all right-handed.
- Joint space
One coordinate per joint, in that joint’s own units. This is what the motion controller commands and what
kinematicsForward()is given. - Machine frame
Fixed to the machine bed, with the X, Y and Z of CNC Machine Overview. Nothing rotates it.
- Work frame
Fixed to the workpiece.
kinematicsForward()reports in it, andkinematicsInverse()is given it. Where no rotary carries the work it coincides with the machine frame. Where one does, it turns with the table and the module undoes that rotation, so that a G-code position keeps naming the same feature of the part however the table is set. - Tool frame
Fixed to the tool. Its origin is the controlled point of Controlled Point, the tool tip when a tool length offset is in effect and the tip of the spindle otherwise. Its third axis is the tool axis, The Tool Frame.
The interface calls the work frame "world": the forward and inverse take a struct EmcPose *world, and the motion controller speaks of world mode. That name is historical and stays in the code. This chapter says work frame, because the frame is attached to the workpiece and not to the room.
A pose is always a pair of frames, the moving one and the one it is measured against, and the two halves of this chapter use different pairs deliberately.
Positions are measured in the work frame, which is what makes a program independent of how the table is set.
Orientations are measured against the machine frame, and there are two of them. A module reports the tool frame and the work frame separately, each in machine coordinates. A consumer that wants the tool in workpiece coordinates composes them:
tool_in_work = transpose(work) * tool
A frame written as a matrix is the rotation whose columns are its axes in the coordinates it is measured against, so the tool axis in workpiece coordinates, the vector a tilted work plane asks the machine to reach and the one existing TWP code reads out of matrix[0,2], matrix[1,2] and matrix[2,2], is the third column of that product.
The pair is reported rather than the product because the product cannot be taken apart again, and a consumer that has to place both bodies needs each one against something that does not move. A simulation model draws the workpiece in one place and the tool in another; given only the product it can recover neither. Where only the tool turns, the work frame is the identity; where only the work turns, the tool frame is. A machine that turns both returns a real pair.
3. Rotation Sense
LinuxCNC states its rotation convention in Rotational Axes:
The rotational axes are measured in degrees as wrapped linear axes in which the direction of positive rotation is counterclockwise when viewed from the positive end of the corresponding X, Y, or Z-axis. […] Clockwise or counterclockwise is from the point of view of the workpiece.
The second sentence is the one that matters here. The rotation described is that of the tool relative to the workpiece. Where the rotary carries the tool that is also the direction the physical axis turns; where it carries the work the table turns the other way, and the module converts between the two. This is the convention of ISO 841, which describes all motion as motion of the tool relative to the workpiece and primes the axes of a machine that moves the work: a table turning about Z is +C' when it produces the tool motion called +C.
So: given a pose whose C value increases, the tool moves counterclockwise about work Z seen from the workpiece, whichever member physically turns.
3.1. conventional-directions
trtfuncs.c and maxkins.c carry a conventional-directions HAL pin that selects the sign of the rotary terms, and default it to false, which is the opposite sense. Existing configurations keep working; new configurations set it true.
Leaving it false costs two things. The direction a program runs in depends on a HAL pin rather than on the G-code. And the rotary values the module reports are the raw joint values,
pos->a = joints[JA];
pos->c = joints[JC];
while the translations in the same call were computed with the opposite sign, so the returned pose does not describe its own orientation. A caller cannot rebuild the tool frame from pos->a, pos->b and pos->c without separately knowing how the pin is set. That is the immediate reason the tool frame has to be an answer from the module rather than something a caller derives from the pose.
4. The Tool Frame
4.1. The tool axis
The tool axis is the third axis of the tool frame. It points from the tip towards the holder, away from the material.
It is a direction, not a distance, and is unrelated to the tool length: the length is the scalar the tool-length pin carries, and the tool axis is the direction that length is applied along.
Where it points for a given joint set is whatever the machine’s geometry makes it. A plain vertical mill has [0, 0, 1] in machine coordinates at all times, and a machine whose spindle is parallel to Z with its rotaries at zero has it there too, but that is a property of those machines and not a rule. pumakins with its supplied parameters has [0, 0, -1] with every joint at zero, and genserkins takes its Denavit-Hartenberg parameters from HAL pins, so for that module the question has no fixed answer at all.
4.2. Native frames that point the other way
Robot kinematics name the same line in the opposite sense. ISO 9787 clause 5.3 places the mechanical interface coordinate system at the centre of the flange, where the "+Zm axis points perpendicularly away from the mechanical interface", which runs holder towards tip. The Denavit-Hartenberg approach vector is the same sense. pumakins builds that frame and uses it, reaching the tip by adding the tool length along the third column:
hom.tran.x = hom.tran.x + hom.rot.z.x*PUMA_D6;
Both senses come from a standard for a class of machine, and the tree contains both. What a module reports is the machine tool sense, tip towards holder, because that is the direction a tilted work plane commands and what machine Z already means to a mill operator.
Turning one sense into the other is not a change of sign. Negating the third column leaves a matrix of determinant -1, a reflection, which is not a frame any machine can hold. Reversing the tool axis and staying right-handed takes a half turn about one of the two transverse axes, and which one is chosen decides where tool X lands.
Because it is a rotation in its own right, a module declares it rather than applying it by hand, in the native field of its ops table. Shared code applies it and checks once, at load, that it is orthonormal with determinant +1. TOOL_FRAME_SPINDLE is the identity, for a module whose maths is already in the convention; TOOL_FRAME_FLANGE is the half turn a Denavit-Hartenberg module needs. Keeping it in one place makes it greppable and stops the next such module quietly choosing the other half turn, which would be right about the tool axis and wrong about tool X.
The declaration is fixed when the module is written and nothing changes it at runtime. A machine whose native frame moved while running would be a machine whose geometry moves underneath the program.
4.3. Tool X
A tilted work plane commands only where the tool points. Reaching that direction uses both rotaries of a five-axis machine, and the rotation of the tool about its own axis is then whatever the chain leaves rather than anything the program chose. For cutting that does not matter, the cutter being a solid of revolution. It matters as soon as the tool frame is used as a coordinate system for programming, which is what G68.2 does: the operator writes X and Y moves in the tilted plane and has to know where its X points.
So the software places it, through a virtual rotation about the tool axis applied after the physical joints. It is the pre-rot pin on the in-tree kinematics components and virtual_rot in the TWP code, one quantity under two names. A machine with no such pin has no say in the matter: its tool X is whatever the chain produces, and a consumer that needs a defined one applies the rotation itself.
The frame a module reports is the joints' alone and does not carry the virtual rotation. The rotation is a rotation of the coordinate system, not of the machine, and that is where the other controls keep it: Heidenhain’s COORD ROT rotates the working plane and Fanuc’s G68.2 feature coordinate system carries its own X. Reporting the joints alone also keeps the orientation inverse honest: the turn it reports about the tool axis is then the value to apply, not a difference from whatever is applied already. A consumer that wants tool X as programmed, a preview or a model, multiplies the frame by the rotation on the pin.
Important
By default, tool X lies parallel to the machine XY plane. Where the tool axis is vertical and that leaves tool X free, tool X is machine X. G68.3 R rotates the frame from there.
This fixes tool X only up to a half turn, two opposite directions both being horizontal. Where a module has to choose, it takes the one that keeps the frame continuous with the previous pose.
4.4. Deriving the default rotation
The convention is stated rather than a formula because the formula differs from machine to machine and follows from the convention. Write the tool orientation as the product of the primary, secondary and virtual rotations:
M = Rp(theta_1) * Rs(theta_2) * Rz(tc)
Tool X is the first column of M, so "tool X is horizontal" is the statement that M[2][0] is zero. Solving that for tc gives the default.
For a nutating head of nutation angle v, writing Sv = sin(v), Cv = cos(v), Ss = sin(theta_2), Cs = cos(theta_2), s = Cs + Cv*Cv*(1 - Cs) and t = Sv*Cv*(1 - Cs), the two nutating machines in the tree have different secondary rotations, and so different bottom rows:
| machine | bottom row of Rs |
resulting default |
The two formulas look unrelated and are the same rule. Apply either to the other machine and the result is a frame whose tool Y is horizontal, a quarter turn from what was wanted, and no test in the tree notices: the tool still points where it was told to point, and only the meaning of X and Y in the tilted plane has changed. A module that documents its Rs and cites this rule can be checked. One that documents only its tc formula cannot.
5. What a Module Reports
Position, through kinematicsForward() and kinematicsInverse(), in the work frame.
Orientation, through kinematicsWorkFrame() and kinematicsToolFrame(), each against the machine frame, as Frames describes. The consumers are tilted work plane handling, tool length compensation along a tilted axis, previews and simulation models, and probing routines that have to say which way the stylus faces.
The joint values that reach a requested orientation, through kinematicsToolFrameInverse(), which is the inverse of the pair above and the question a tilted work plane asks when it has to orient the machine. The Orientation Inverse says what it answers.
How joint motion follows world motion, through kinematicsJacobian(), so that a feed can be checked against the joint velocity and acceleration it will actually demand, and so that proximity to a singularity is a number rather than a surprise. The Jacobian says what it answers and in which units.
All of these are functions of the joint values and the module’s own geometry. None needs state carried between calls, and none needs the module to be running in a realtime thread to be useful: the interesting callers, a limit check before a move and a preview before a program runs, are not in the servo loop. The Parameter Block is how a module is written so that they can call it.
6. The Orientation Inverse
Pointing the tool somewhere is the question a tilted work plane asks on every orienting move, and the question a program written as tool vectors asks on every block. It is the inverse of the tool frame: not where the tool points for these joints, but which joints point it there.
It has more than one answer. A five-axis machine reaches a given tool axis two ways, one with the secondary rotary positive and one with it negative, and which of the two is wanted depends on the joint limits and on what the operator asked for, shortest move or one direction of rotation only. So the module reports every set of joint values that reaches the orientation and stops there. It does not apply the joint limits and it does not rank the answers, because neither is geometry: a module that picked for the caller would be picking with less to go on than the caller has.
The request is a tool axis, and optionally a tool x as well. The two have to be at right angles, being two axes of one frame.
Asking for tool x does not require a joint that can reach it. A five-axis machine spends both rotaries on the tool axis, and the turn about that axis is not a joint at all: it is the virtual rotation of The Tool Frame. So the answer comes back in two parts. Where the joints can place tool x, on a machine with a third orientation joint, they do, and the reported turn is zero. Where they cannot, the joints reach the axis and the reported turn finishes the job. The caller writes one path either way, and which kind of machine it has is a number that happens to be zero rather than a branch.
This is what the controls do. A Heidenhain PLANE VECTOR block carries the normal and the base vector together, the normal reached by the rotaries and the base vector applied as a rotation of the coordinate system; SEQ then picks between the rotary solutions. A Fanuc G68.2 defines the plane including where its X points, and G53.1 moves the rotaries to align the tool axis. Neither refuses a program for naming both directions on a five-axis machine, and neither should this.
Some requests still do not pin the machine down. A five-axis machine asked to point the tool along the axis its primary rotary turns about can hold any primary angle; a machine with three orientation joints asked only for a tool axis has a whole curve of solutions. In both cases the answer is a continuum, so one point of it is reported, the one nearest where the machine already is, along with the number of directions left free. A caller that hands back a list of samples from a curve as though they were alternatives is telling the operator something false.
Which joints may take part is the caller’s decision, not the module’s. A rotary table turns the tool against the work as surely as a head rotary does, so a machine with a table and a two-axis head has three orientation joints and a bare tool axis leaves one of them free. Whether the table is used for that is a machining choice: Heidenhain names the axes a tilt may use with M138, and its PLANE lets the operator pick TABLE ROT, turn the table to place tool X, or COORD ROT, leave the table and rotate the coordinate system. So the request names the joints to hold. Holding the table gives the two head solutions and the turn about the tool that finishes the frame, which is what the TWP remap computes; holding nothing lets the table place tool X and the turn comes back zero.
The request is taken as a program carries it. A direction written to a few digits is a unit vector only to within its rounding, and a tool X written the same way is at right angles to the axis only to within it, so both are normalised on the way in and only a vector that is not a direction at all is refused.
6.1. What a module has to supply
Nothing, if it already reports its frames. The shared code answers the question by searching: it finds which joints move transpose(work) * tool, and solves for them. That is the whole reason the frames are worth reporting. A module that supplies them gets the inverse without deriving anything.
A module with a closed form registers it and that is used instead. It is faster than a search and it knows its own degenerate poses without having to discover them. The nutating heads are the case in point: for those,
cos(secondary) = (Kzz - Cv^2) / (1 - Cv^2)
with Cv = cos(v) for a nutation angle v and Kzz the z component of the requested tool axis, and the primary follows from the other two components. Both roots of the arc cosine are solutions, which is where the pair of answers comes from.
The search is not a realtime routine. How long it takes depends on the machine and on the request, and the callers that want it, orienting a tilted work plane and previewing a program, are not in the servo loop.
7. The Jacobian
A feed is a speed in the work frame. What the machine has to deliver is a speed at each joint, and on any kinematics that is not the identity the two are related by where the machine is. The Jacobian is that relation at one pose: how each joint responds to a unit rate of each pose coordinate.
jac[j][a] = d joint[j] / d pose[a]
Rows are joints. Columns are the pose coordinates in EmcPose order, X Y Z A B C U V W. It is the derivative of kinematicsInverse(): multiplied by a pose velocity it gives the joint velocity motion will command, which is what a feed limit compares with the joint limits. Joint j binds when
|jac[j] . tangent| * F
exceeds that joint’s velocity limit, tangent being the direction of the move in pose coordinates and F the feed along it. The acceleration limit follows from a second Jacobian taken further along the path, with no more from the module. A row that grows without bound is a pose approaching a singularity, where no world speed is slow enough for the joints to follow.
7.1. Units
Each entry is in joint units per pose unit, whatever units the module’s own forward and inverse already use. Nothing is converted: a caller that feeds pose rates in EmcPose units gets joint rates in the units motion already commands, and never has to know which unit a rotary joint is in. On every module in the tree both are degrees, so a table rotary’s own row is a 1 in its own column, and a robot’s rotary rows carry degrees per millimetre against the linear columns.
This is why the Jacobian, unlike the orientation inverse, does not need the interface to name the rotary joint unit. Every number in it is a ratio of quantities that already pass through kinematicsForward() and kinematicsInverse(), and the caller never combines it with anything measured in another unit.
7.2. Frame
The columns are pose coordinates, so the answer lives in the work frame, where kinematicsForward() reports positions. The A, B and C columns are rates of the pose words, the wrapped linear axes the planner already treats as coordinates, and not an angular velocity vector: on a machine that carries the work the forward writes the rotary joint into the pose word, and that column says exactly that, a 1 for its own joint.
That makes this a different object from the frames of Frames, and the two rules are kept apart deliberately. A frame is an orientation, and a renderer placing two bodies needs each against something fixed, so frames are reported against the machine. A Jacobian is a derivative of the pose, and everything that uses it multiplies it by a pose rate, so it is reported where the pose is. A module whose maths produces a twist in the machine frame, which is what the Denavit-Hartenberg modules produce, turns it into pose word rates through the matrix of the axes each pose word turns about, once, inside the module. genserkins does this, and having it written once there is worth more than the closed form itself, since every consumer would otherwise guess it.
7.3. What a module has to supply
Nothing. If a module supplies no Jacobian, the shared code computes one by central differences: it calls the module’s inverse eighteen times, stepping each pose coordinate a small amount to either side on the solution branch the inverse flags select, and differences the results. The answer is as precise as the inverse itself; behind an inverse that iterates, that is the iteration’s convergence tolerance divided by the step. Modules built on switchkins.c answer this way for every type whose ops table has no Jacobian; an identity type answers exactly.
This cost matters because kinematicsJacobian() is meant to run in the servo thread, where checking a feed limit calls it once per cycle: each call then costs eighteen inverses. On the closed-form inverses in the tree that is under two microseconds. genserkins, the one module whose inverse iterates, would cost near eighty microseconds per call this way, against under two for the geometric Jacobian it supplies instead.
So a module whose inverse iterates should supply a closed-form Jacobian, as below. Nothing enforces this. A module that supplies none still gets a correct Jacobian, just one that costs eighteen inverses and carries the iteration’s precision, which behind an iterating inverse is too slow for the servo thread.
A module with a closed form puts it in the jacobian field of its ops table. It is exact, it costs what the inverse costs, and it knows its own singular poses rather than discovering them as an inverse that fails a step away from the pose. Every module in the tree supplies one. The two arms whose inverse is a chain of arc tangents, pumakins and three21kins, take theirs from their Denavit-Hartenberg chain through kinsJacobianFromDhArm(), which any six-joint serial arm can call with its own table, written in the modified convention of Craig’s Introduction to Robotics: each joint’s axis crossed with the vector from it to the tool point gives the point’s rate, the axis itself the angular rate, and the six by six that makes is inverted and taken through the roll, pitch and yaw rates the pose words are.
A module reading its rotary angles from the joint argument of the inverse rather than from the pose, which the nutating heads do, has an inverse whose derivative about the pose is not the coupling the machine has. Such a module supplies the closed form, taken against the pose.
8. The Parameter Block
Everything above is a function of the joint values, the tool and the machine’s geometry. A module written the old way reads its geometry from HAL pins it created, keeps its kinematics type and its iteration scratch in statics, and so can only answer for the machine as it is now, from inside the realtime thread. Anything else that needs the same maths, a planner evaluating poses the machine has not reached, task checking a program at load, a tool asking what if, had to carry a second copy of it, and the two copies drift.
A module is written instead as functions of two blocks the caller supplies. kins_params describes the machine: the kinematics type, the joint map from coordinates=, the tool offset, and the geometry as an array of doubles. One copy may be shared by any number of callers, since nothing writes it during a call. kins_scratch is what one caller carries between its own calls: the pose an iterating forward last found, which seeds the next, and what the module reports about the call it just made. It is never shared between callers, so motion and a planner evaluating the same module cannot disturb each other.
8.1. The table
A module declares its geometry as a table of named entries, one per value it reads. The name is the pin name the config already uses, less the module prefix, so nothing in a config changes.
static const kins_param_desc fiveaxis_params[] = {
{ "pivot-length", KINS_PARAM_FLOAT, KINS_IN, 0, DEFAULT_PIVOT_LENGTH },
enum { P_PIVOT_LENGTH };
An entry is an input, an output, or an input that can be poked (KINS_IO, a HAL_IO pin). The maths reads p->geometry[P_PIVOT_LENGTH] where it read a pin, and writes an output into s->out[] at the same index. An entry flagged as the tool is the tool length along the tool axis; the shared code puts its value in p->tool.tran.z as well, which is what the maths reads, so that a caller outside realtime can supply the tool from the tool table without there being a pin.
8.2. The ops table
The maths of one kinematics type is a kins_ops table: the forward and inverse, the optional work and tool frames with the native rotation that relates the tool frame to the convention, and the optional Jacobian. A type whose forward iterates from the pose it is handed says so, and the shared code seeds it with the last answer after a switch. A type also says what it IS: identity marks the no-transform type G13.1 cancels to, primary the working transform G43.4 switches to (see the Switchable Kinematics chapter). A module with several types has one geometry table and one ops table per type, registered with switchkinsRegisterOps(); a module with one type describes itself in a kins_module and links kins_single.c.
8.3. What the shared code does
In realtime it makes one HAL pin per table entry, copies the pins into the block before every call and the outputs back after it, and supplies the classic entry points, kinematicsForward() and the rest, so that motion sees no difference. It also exports kinematicsSetTool(), through which motion hands the module the tool offset in effect whenever that changes, so the tool comes from the tool table and not from a net the config had to remember. A table entry flagged as the tool is read from its pin only until motion has sent anything; after that the pin is overwritten with motion’s value, and the shared code says once if the pin is left disagreeing with it, which is a config setting a tool length where the tool table should. Motion references the call weakly, so a module written before it still loads and keeps its pin.
Outside realtime a module exports kinsDescribe(), which hands a caller its table and the ops of each type; the caller fills a block from wherever it likes and asks the same functions through kinsOpsForward(), kinsOpsInverse(), kinsOpsJacobian() and the frame calls, with the same defaults applied, so both sides get the same answers. The non-realtime loader in kinematics_userspace/ binds the pins of the running module by the table’s names. Its tool is the caller’s where the caller gives one through kinematicsUserSetTool(), since a planner knows what a segment runs under better than the machine does; otherwise it is motion’s, from motion’s own offset pins, and the loader says once when the module’s tool pin disagrees with them. kinslimits is built on it.
A module that does not provide the form keeps working as it did. It just cannot be evaluated outside realtime, which the loader reports.
8.4. What stays outside the block
The kinematics type is in the block, so a caller evaluating a program that switches type puts the type each block will run under in its own block, and nothing is switched globally. The tool is in the block, from motion in realtime and from the caller outside it. The joint map is in the block, from coordinates=. Nothing else the maths needs exists, and a module that finds it needs something else has found a parameter it should declare.
9. Writing a Module
- Frames
Report positions in the work frame, so a rotary that carries the work is undone in
kinematicsForward(). Report the work frame and the tool frame separately, each against the machine frame, so that a consumer placing both bodies can. - Signs
Positive A, B and C are counterclockwise about work X, Y and Z viewed from the positive end, describing the motion of the tool relative to the workpiece. A new module does not offer a pin that reverses this.
- Tool axis
Tip towards holder. A module whose maths is written with the Denavit-Hartenberg approach vector declares the half turn that relates the two, rather than applying it by hand.
- Tool X
The default virtual rotation puts tool X parallel to the machine XY plane. Derive the value from the module’s own rotation matrices, and write those matrices down in the module.
- Orientation inverse
A module that reports its frames gets it from the shared search and needs to do nothing. Register a closed form only where one exists, and where it does, say which poses it treats as degenerate.
- Jacobian
Rows are joints, columns are pose coordinates, entries in the units the forward and inverse already use, reported where the pose is. A module with a closed form inverse differentiates it and registers the result; one without lets the shared code difference the inverse.
- Geometry stays in the module
Whatever a consumer needs to know about the machine’s shape is answered by the module. A consumer that restates it has taken a copy that nothing keeps in step, which is the situation this chapter exists to end.
- No state
Write the maths as functions of the parameter block and the scratch, as The Parameter Block describes: geometry in the table, the kinematics type and the tool from the block, and anything carried between calls in the scratch. A static in a module is a second machine that only the realtime thread can see.
- Mount orientation is not this
A tool or holder mount orientation is a different quantity: a right-angle head, a tool held at an angle, an end effector clocked on its flange. Those vary from setup to setup and belong with the rest of the tool data, addressed from the program where the interpreter can see them, and not in HAL alone where lookahead and preview cannot see them and where they can move underneath a running program. The tool table and
G43.1already carry per-tool A, B and C words, which is the right addressing route, but they shift the rotary axis reading and configurations depend on that, so a mount orientation is a new field rather than a reinterpretation of that one. It wants to be stated as a frame, which can be checked for orthonormality and determinant, rather than as three angles whose ordering convention is written down nowhere.
10. References
CNC Machine Overview, for the axis nomenclature and the rotation convention this chapter builds on.
5-Axis Kinematics, for worked transformations of the table-rotary and tilting-table configurations.
Switchable Kinematics, for how a machine presents more than one of these models at once.
ISO 841, Industrial automation systems and integration, Numerical control of machines, Coordinate system and motion nomenclature.
ISO 9787, Robots and robotic devices, Coordinate systems and motion nomenclatures, clause 5.3, for the flange frame the robot modules follow.
